Instance being monitored by copy monitor
2 ANTWORTEN 2
Nachricht 1 von 3
luisPDAN6
165 Aufrufe, 2 Antworten
I am trying to understand this error but it is hard.
I created the leftmost column of face based elements over a roof with flat and curved section. If I keep copying the first copy to columns 2,3,4 I face no issue. But I when try to copy columns 1,2,3,4 to another position, I get highlighted on columns 2,3,4 (in the roof section that is curved in section).
So it seems Revit sets on the columns 2,3,4 a setting for those elements that does not allow me to copy them.
Anybody with the same experience? Any way to solve this? The array command also does not work.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: luisPDAN6
Create similar not viable?
Nachricht 3 von 3
If those are the only ones you have trouble with then place them directly instead of copy.  If you have a lot more to copy then share a section showing the relationship between the families and the curved roof area.
