I am trying install revit 2017 . After installation I click on the EXE file and it doesnt run at all.
My system is 64 bit with windows 10.
Hello @Anonymous,
I would suggest you try solution in the link below.
2017: How to Complete a Clean Install and Uninstall of Revit products
I finally managed to insatll it afetr i restarted my system. However the issue is that I don't have site design options , and some of the other features also failed to install. I have tried to install the extension but it coud nOT load as I am using revit 2017.
@Anonymoushello mate, if you under subscription go to your account under product update it's a separate file that need to install. thanks
@Anonymous hello mate, are you under autodesk subscription? if yes here is the LINK . thanks
I have found it but another issue is taht I can NOT open family templates
@Anonymous hello mate, you need to go to the top left corner big R > options > file location and load the template. thanks
I cant load it undortunately . I can NOT see any RTE files at the destination.
Open the installation package and install the library.
See: Revit: Templates and families not installed
@Anonymous hello mate , go to your window explorer > program data and check if you installed the templates/library, if not then just follow @robert.klempau suggestion you need to install it. thanks
I had read the article a while ago but the issue is tath I do NOT have the revit content library in the control panel unfortunately.
I always used one of the steps you guys suggested before biut my issue now is that I do NOT have any template folders on my pc at all.
this link has similar situation to my problem .
