Installation problem Revit 2017
peter
peter
I am trying to install Revit 2017 on Windows 7 64 bit and it fails - log file below.
I used the Autodesk Uninstall Tool to uninstall Revelit Kepler and have virus checking and the firewall turned off.
I had a similar problem with AutoCAD 2017 but was able to install by downloading the files first. This option doesn't appear to be available for Revit 2017.
My broadband speed is quite slow 2-3Mb/s
Any suggestions would be much appreaciated.
Many thanks
Peter
2016/6/9:09:14:11 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:09:14:11 Peter OTTER Path_Length: 155
2016/6/9:09:14:11 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:09:14:11 Peter OTTER Launch
2016/6/9:09:14:11 Peter OTTER CommandLine /akamai /sid a1b3A000009CN6vQAG /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a...
2016/6/9:09:14:11 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AIB08.tmp
2016/6/9:09:30:39 Peter OTTER === Setup ended ===
2016/6/9:09:14:13 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:09:14:13 Peter OTTER Path_Length: 155
2016/6/9:09:14:13 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AIB08.tmp
2016/6/9:09:14:13 Peter OTTER Launch
2016/6/9:09:14:31 Peter OTTER Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:09:14:32 Peter OTTER Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:09:14:34 Peter OTTER Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:09:30:36 Peter OTTER Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:09:30:37 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AIB08.tmp\Setup\RevitSetup.dll
2016/6/9:09:30:37 Peter OTTER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/6/9:09:30:41 Peter OTTER PageOpen LaunchDialog
2016/6/9:09:37:51 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AIB08.tmp\Setup\RevitSetup.dll
2016/6/9:09:37:51 Peter OTTER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/6/9:09:39:04 Peter OTTER PageOpen LicenseDialog
2016/6/9:09:39:04 Peter OTTER PageOpen ProductInfoDialog
2016/6/9:09:39:04 Peter OTTER PageOpen ProductSelectionDialog2
2016/6/9:09:39:41 Peter OTTER PageOpen FullProgressDialog
2016/6/9:09:39:42 Peter OTTER Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:09:39:42 Peter OTTER Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:09:39:43 Peter OTTER Download Play VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:40:05 Peter OTTER Download Complete VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:40:05 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/6/9:09:40:41 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1603
2016/6/9:09:40:43 Peter OTTER Download Play VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:41:09 Peter OTTER Download Complete VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:41:09 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/6/9:09:42:36 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1603
2016/6/9:09:42:37 Peter OTTER Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:43:31 Peter OTTER Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:43:32 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2015.log
2016/6/9:09:43:39 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/6/9:09:43:39 Peter OTTER Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:44:26 Peter OTTER Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:09:44:26 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x64_2015.log
2016/6/9:09:44:27 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/6/9:09:44:28 Peter OTTER Download Play RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2016/6/9:09:46:37 Peter OTTER Download Complete RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2016/6/9:09:46:46 Peter OTTER Installing Autodesk® Revit® Content Libraries 2017:  TRANSFORMS=":en-us.mst;C:\Users\Peter\AppData\Local\Temp\_AIB08.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/9:11:20:21 Peter OTTER Install Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:11:20:21 Peter OTTER WebInstaller2016/6/9:11:37:42 Peter OTTER Download Play RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:12:25:17 Peter OTTER Download Aborted RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:12:25:17 Peter OTTER Install Autodesk® Revit® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/6/9:12:26:41 Peter OTTER Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:12:26:46 Peter OTTER PageOpen InstallCompleteDialog
2016/6/9:12:46:38 Peter OTTER === Setup ended ===
2016/6/9:13:06:34 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:13:06:34 Peter OTTER Path_Length: 155
2016/6/9:13:06:34 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:13:06:34 Peter OTTER Launch
2016/6/9:13:06:34 Peter OTTER CommandLine /akamai /sid a1b3A000009CQI1QAO /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a...
2016/6/9:13:06:34 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AICF83.tmp
2016/6/9:13:18:19 Peter OTTER === Setup ended ===
2016/6/9:13:06:39 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:13:06:39 Peter OTTER Path_Length: 155
2016/6/9:13:06:39 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AICF83.tmp
2016/6/9:13:06:39 Peter OTTER Launch
2016/6/9:13:06:41 Peter OTTER Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:13:06:41 Peter OTTER Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:13:06:42 Peter OTTER Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:13:18:18 Peter OTTER Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:13:18:18 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AICF83.tmp\Setup\RevitSetup.dll
2016/6/9:13:18:18 Peter OTTER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/6/9:13:18:19 Peter OTTER PageOpen LaunchDialog
2016/6/9:13:18:39 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AICF83.tmp\Setup\RevitSetup.dll
2016/6/9:13:18:39 Peter OTTER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/6/9:13:19:52 Peter OTTER PageOpen LicenseDialog
2016/6/9:13:19:52 Peter OTTER PageOpen ProductInfoDialog
2016/6/9:13:19:52 Peter OTTER PageOpen ProductSelectionDialog2
2016/6/9:13:20:00 Peter OTTER PageOpen FullProgressDialog
2016/6/9:13:20:03 Peter OTTER Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:13:20:03 Peter OTTER Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:13:20:04 Peter OTTER Download Play VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:20:25 Peter OTTER Download Complete VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:20:25 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/6/9:13:20:53 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1603
2016/6/9:13:20:54 Peter OTTER Download Play VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:21:12 Peter OTTER Download Complete VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:21:12 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/6/9:13:22:05 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1603
2016/6/9:13:22:06 Peter OTTER Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:22:44 Peter OTTER Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:22:44 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2015.log
2016/6/9:13:22:58 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/6/9:13:22:59 Peter OTTER Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:23:33 Peter OTTER Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:13:23:33 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x64_2015.log
2016/6/9:13:23:34 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/6/9:13:23:35 Peter OTTER Download Play RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2016/6/9:13:24:39 Peter OTTER Download Complete RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2016/6/9:13:24:43 Peter OTTER Installing Autodesk® Revit® Content Libraries 2017:  TRANSFORMS=":en-us.mst;C:\Users\Peter\AppData\Local\Temp\_AICF83.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/9:14:05:25 Peter OTTER Install Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:14:05:27 Peter OTTER Download Play RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:14:39:20 Peter OTTER Download Aborted RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:14:39:20 Peter OTTER Install Autodesk® Revit® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/6/9:14:40:40 Peter OTTER Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:14:40:46 Peter OTTER PageOpen InstallCompleteDialog
2016/6/9:14:58:21 Peter OTTER === Setup ended ===
2016/6/9:14:58:31 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:14:58:31 Peter OTTER Path_Length: 155
2016/6/9:14:58:31 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:14:58:31 Peter OTTER Launch
2016/6/9:14:58:31 Peter OTTER CommandLine /URL "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a... /skipPI /Trial /akamai
2016/6/9:14:58:31 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI4E64.tmp
2016/6/9:14:58:45 Peter OTTER === Setup ended ===
2016/6/9:14:58:42 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:14:58:42 Peter OTTER Path_Length: 155
2016/6/9:14:58:42 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI4E64.tmp
2016/6/9:14:58:42 Peter OTTER Launch
2016/6/9:14:58:43 Peter OTTER Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:14:58:44 Peter OTTER Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:14:58:44 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AI4E64.tmp\Setup\RevitSetup.dll
2016/6/9:14:58:44 Peter OTTER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/6/9:14:58:45 Peter OTTER PageOpen LaunchDialog
2016/6/9:14:59:01 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AI4E64.tmp\Setup\RevitSetup.dll
2016/6/9:14:59:01 Peter OTTER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/6/9:15:01:18 Peter OTTER PageOpen LicenseDialog
2016/6/9:15:01:33 Peter OTTER === Setup ended ===
2016/6/9:15:01:33 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:15:01:33 Peter OTTER Path_Length: 155
2016/6/9:15:01:33 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:15:01:33 Peter OTTER Launch
2016/6/9:15:01:33 Peter OTTER CommandLine
2016/6/9:15:01:33 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI1673.tmp
2016/6/9:15:01:58 Peter OTTER === Setup ended ===
2016/6/9:15:01:36 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:15:01:36 Peter OTTER Path_Length: 155
2016/6/9:15:01:36 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI1673.tmp
2016/6/9:15:01:36 Peter OTTER Launch
2016/6/9:15:04:33 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:15:04:33 Peter OTTER Path_Length: 155
2016/6/9:15:04:33 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:15:04:33 Peter OTTER Launch
2016/6/9:15:04:33 Peter OTTER CommandLine /akamai /sid a1b3A000009CQI1QAO /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a...
2016/6/9:15:04:33 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AID4B3.tmp
2016/6/9:15:04:41 Peter OTTER === Setup ended ===
2016/6/9:15:04:39 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:15:04:39 Peter OTTER Path_Length: 155
2016/6/9:15:04:39 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AID4B3.tmp
2016/6/9:15:04:39 Peter OTTER Launch
2016/6/9:15:04:40 Peter OTTER Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:15:04:40 Peter OTTER Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:15:04:40 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AID4B3.tmp\Setup\RevitSetup.dll
2016/6/9:15:04:40 Peter OTTER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/6/9:15:04:41 Peter OTTER PageOpen LaunchDialog
2016/6/9:15:05:03 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AID4B3.tmp\Setup\RevitSetup.dll
2016/6/9:15:05:03 Peter OTTER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/6/9:15:06:18 Peter OTTER PageOpen LicenseDialog
2016/6/9:15:06:18 Peter OTTER PageOpen ProductInfoDialog
2016/6/9:15:06:18 Peter OTTER PageOpen ProductSelectionDialog2
2016/6/9:15:06:28 Peter OTTER PageOpen FullProgressDialog
2016/6/9:15:06:29 Peter OTTER Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:15:06:29 Peter OTTER Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:15:06:29 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/6/9:15:07:02 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1603
2016/6/9:15:07:03 Peter OTTER Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:15:07:03 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/6/9:15:08:29 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1603
2016/6/9:15:08:30 Peter OTTER Download Skipped VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:15:08:30 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2015.log
2016/6/9:15:08:31 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/6/9:15:08:31 Peter OTTER Download Skipped VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:15:08:31 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x64_2015.log
2016/6/9:15:08:32 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/6/9:15:08:32 Peter OTTER Download Skipped RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RCL_x...
2016/6/9:15:08:37 Peter OTTER Installing Autodesk® Revit® Content Libraries 2017:  TRANSFORMS=":en-us.mst;C:\Users\Peter\AppData\Local\Temp\_AID4B3.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/6/9:15:50:26 Peter OTTER Install Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:15:50:27 Peter OTTER Download Play RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:16:23:57 Peter OTTER Download Aborted RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:16:23:57 Peter OTTER Install Autodesk® Revit® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/6/9:16:25:04 Peter OTTER Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
2016/6/9:16:25:07 Peter OTTER PageOpen InstallCompleteDialog
2016/6/9:16:50:10 Peter OTTER === Setup ended ===
2016/6/9:17:00:54 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:17:00:54 Peter OTTER Path_Length: 155
2016/6/9:17:00:54 Peter OTTER Current Directory C:\Autodesk\Revit_2017_G1_Win_64bit_wi_en-US
2016/6/9:17:00:54 Peter OTTER Launch
2016/6/9:17:00:54 Peter OTTER CommandLine /akamai /sid a1b3A000009CUEmQAO /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/Revit_2017_G1_Win_64bit_wi_en-US_Setup.exe?a...
2016/6/9:17:00:54 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI576B.tmp
2016/6/9:17:00:59 Peter OTTER === Setup ended ===
2016/6/9:17:00:56 Peter OTTER === Setup started on OTTER by Peter ===
2016/6/9:17:00:56 Peter OTTER Path_Length: 155
2016/6/9:17:00:56 Peter OTTER Current Directory C:\Users\Peter\AppData\Local\Temp\_AI576B.tmp
2016/6/9:17:00:56 Peter OTTER Launch
2016/6/9:17:00:58 Peter OTTER Download Skipped SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:17:00:58 Peter OTTER Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/SETUP...
2016/6/9:17:00:58 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AI576B.tmp\Setup\RevitSetup.dll
2016/6/9:17:00:58 Peter OTTER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/6/9:17:00:59 Peter OTTER PageOpen LaunchDialog
2016/6/9:17:01:10 Peter OTTER PageOpen LicenseDialog
2016/6/9:17:01:10 Peter OTTER PageOpen ProductSelectionDialog2
2016/6/9:17:01:36 Peter OTTER PageOpen LicenseDialog
2016/6/9:17:01:37 Peter OTTER PageOpen LaunchDialog
2016/6/9:17:01:50 Peter OTTER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Peter\AppData\Local\Temp\_AI576B.tmp\Setup\RevitSetup.dll
2016/6/9:17:01:50 Peter OTTER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2016/6/9:17:03:01 Peter OTTER PageOpen LicenseDialog
2016/6/9:17:03:01 Peter OTTER PageOpen ProductInfoDialog
2016/6/9:17:03:01 Peter OTTER PageOpen ProductSelectionDialog2
2016/6/9:17:03:53 Peter OTTER PageOpen FullProgressDialog
2016/6/9:17:03:53 Peter OTTER Download Skipped STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/START...
2016/6/9:17:03:53 Peter OTTER Download Skipped VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:17:03:53 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/6/9:17:04:25 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1603
2016/6/9:17:04:25 Peter OTTER Download Skipped VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:17:04:25 Peter OTTER Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/6/9:17:05:52 Peter OTTER Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1603
2016/6/9:17:05:53 Peter OTTER Download Skipped VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:17:05:53 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x86_2015.log
2016/6/9:17:05:55 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/6/9:17:05:56 Peter OTTER Download Skipped VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/VCRED...
2016/6/9:17:05:56 Peter OTTER Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Peter\AppData\Local\Temp\vcredist_x64_2015.log
2016/6/9:17:05:57 Peter OTTER Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/6/9:17:06:07 Peter OTTER Download Play RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:17:40:57 Peter OTTER Download Aborted RVT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/RVT_x...
2016/6/9:17:40:57 Peter OTTER Install Autodesk® Revit® 2017 Failed Download Failed, Installation aborted, Result=1603
2016/6/9:17:41:08 Peter OTTER PageOpen InstallCompleteDialog
2016/6/9:21:50:15 Peter OTTER === Setup ended ===
L.Maas
If you download through your account, you can select different download options.
I always choose browser download. Depending on the software package it might need to download several 2 gb files. After that the local extraction and installation should not be a problem..
Louis
Please mention Revit version, especially when uploading Revit files.
peter
Many Thanks EnlInt,
I will try but I don't seem to be able to access the subscription centre at the moment. The only option for Revit 2017 I appeared to have was "Install Now" rather than "Download". Could you tell me how to access the browser download option?
Thanks again.
Peter
L.Maas
I went into my account (https://manage.autodesk.com). Go to the product to be downloaded (in my case building design suite), selected Download then a popup window shows up (see screenshot). Clicking on the "More Options" showed the popup with browser download as in my screenshot.
Louis
peter
Thanks again, I will try as soon as I can access the site.
peter
Hello Louis,
Found it.
Very many thanks.
Peter
