I get fatal error message whenever try to access revit icon in revit lt2017 on windows 7
sorry but problem is mislabel with content library installation message.
that message came before the autodesk first solution and worked only for a short period of time
@Anonymous hello, can you post the error messages. have you try to install altest updates and service packs from autodesk and updates your windows OS and see if this helps. thanks
see case #12183824
the first screen shot about the file location is not appearing.
the second screen shot with fatal error message is still a major problem
@Anonymous hello, where is your screen shot? how to see? thanks
unistalled revit and reloaded using multi language version and not English version.
now can only use Revit is administration mode and must open files within Revit.
so revit can be used but not as it should be used.
does anyone knows whats going on?
