Installation Error "while touching AdODIS.run.lock"
fictive_foton
fictive_foton
Hello, I have an Autodesk educational license but I can't install Revit. I've already installed Fusion360 and it works fine, but when I run the Revit installer, there's an error and the following message appears:
"Error while touching
c:\ProgramData/Autodesk/ODIS/AdODISInstaller.run.lock".
I've done some internet research and found that this is probably an ODIS problem, and I'd like to know if there isn't a way to install Revit without going through ODIS.
I'm having the same problem installing all the products I have access to, except Fusion.
What do I have to do to be able to install Revit?
Thank you for your help.
jay_colcombe
I would suggest looking here and reposting too as i have seen this error before on this forum
Subscription, Installation & Licensing - Autodesk Community
Jay Colcombe
Autodesk Certified Instructor
