I have been attempting to install / download various windows from the NBS website but they do not seem to cut into the wall. Both are 70mm thick so unsure what is happening.
I can even seem to cut a void or hole in the wall?
I am sure it is an easy fix - any help appreciated.
edit your window family and check if they provide opening cut on the perimeter of window. thanks
check also this in the window family. thanks
if @ennujozlagam suggestions don't work (but from your description, they should
), can you upload the families for us to look at?
Howard Munsell
share your family here so we can check. thanks
