Inserting data rows into schedules and adding revision information
spm8C88E
spm8C88E
I'm creating a sheet list that includes subconsultant drawings which are not linked in model. I'm adding them as dumb data rows. Is there a way to add revision information for these fields or do i have to create dummy sheets in order to show a revision date in the schedule?
vitorbortoncello
Create a project parameter text type and type the revision
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
mari.shimode
Hi @spm8C88E, you may have solved the issue yourself but did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
