inserting a new point cloud file in an existing revit model
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
420 Aufrufe, 2 Antworten
Hii, I have started with working with point cloud on revit. I am using Pointsense and Edgewise to get the walls, and objetcs. I have already done a model in Revit. I had later a problem with the initial pointcloud. Now I want to insert an other version of pointcloud. I want to know how can I insert it georefrenced with the existing revit model? so that I wouldn't lose my work?? Please HELP !
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
sureshchotrani
als Antwort auf: Anonymous
Actually the process should be as follows:
1. Import the point cloud in Revit(Revit converts it in .pcg) via option orig-to-origin
2. Start preparing the model as per point cloud via help of 3D box sections & other views.
3. For review you can bring the point cloud in Naviswork & append the Revit file.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 3
If using origin to origin , I am afraid that elements are far away from origin which cold limit revit performance
