Insert Window in Mass
Message 1 of 13
Hi all. Which is the easiest way to insert a window in a mass?
Thank you.
Accepted solutions (3)
Replies (12)
Message 2 of 13
You need to create walls or curtain walls from the mass first.
Message 3 of 13
Or...use a curtail wall
Or build an unhosted window.
Message 4 of 13
how can we build an unhosted window?
Message 5 of 13
J450NP13
Create a new family and model it.
Message 6 of 13
You can get by with unhosted windows but be aware that if you later turn you mass to a building shell, you will have to insert them again.  Unless you intend to stay with the mass forever, I would go with a more established route:
- Build a mass
- Create building shell (walls, curtain walls, roofs) and floors based on the mass faces
- Insert fenestrations (doors, windows, openings) to the building shell
It is more sustainable in the long run.
Message 7 of 13
Hi Toan,
If I change parameter of th edoor Wall Closure to Neitehr instead of by host, does this make it UNHOSTED?
Message 8 of 13
I don't understand this question.  Where do you change it?
Message 9 of 13
Toadn,
I have changed material of the Mass from default to brick and I cannot insert a window.
What I am doing wrong then?
Message 10 of 13
David_W_Koch
The out-of-the-box Windows are designed to be hosted by Walls (just like the real world).  They cannot be inserted into a Mass.  As previously mentioned, you can do one of two things:
1.  Generate Walls from the Mass by using the Pick Faces tool when adding a Wall, and picking faces of the Mass.  You then can add a hosted Window family to the Wall(s) generated from the Mass.  (If you later edit the Mass, the Wall(s) will adjust to the revised Mass face.)
2.  Create a Window family that is not hosted to a Wall.  This would be a lot of work, and, if you later want the Windows to be hosted by a Wall, you will have to add new, Wall-hosted Windows, as @ToanDN noted.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 11 of 13
chrisplyler
It makes the door CLOSURE plane unhosted, but not the door family as a whole.
Message 12 of 13
Keith_Wilkinson
You need to assign a wall by face to a face of you mass. Go to Architecture > Wall > Wall by Face. It won't work if you just assign a material to your mass, it's not the same thing.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 13 of 13
dbroad
There seems to be some confusion about what you might be trying to accomplish.  If it is a sculptural building, then using the wall from face option is the way to go.  If you want a sculpted or battered wall, then model the wall as a component in the project.  It won't be mass but will act like a wall and have the form you want.  See image.2016-03-12_8-49-51.png
Architect, Registered NC, VA, SC, & GA.
