have problem to put the view in the porject.
Have two view (level 0 and level 1)
With 1:100 scale in floor plans appears as in pic 1 (too small).
First question: best thing to do in to put the view in a A3 titleblock?
Second question: zooming seems dimension are too large related to the plant.. What can I do...?!
Reducing the scale? 1:50? Or there is possibility to just reduce dimension?
.rvt attached.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You can have several (sizes of) titleblocks in Revit, or different types of the same titleblock family using parameters. You just have to select (or create) a titleblock that will fit your needs for the viewing scale. Or for fitting multiple views ofcourse on the same sheet.
To create new titleblocks:
If you go to New --> Family --> find folder called Titleblocks --> you can select A3 ie. Edit as you like and load it into your project.
btw this is 1:100?? it seems off, bit hard to judge the scale though from the image... could be just a large titleblock.
Duplicate the view (without detailing), set the appropriate view scale and dimension/annotate it from scratch. That's the fastest and easiest way IMO/E.
FWIW: Generally, printed text height should not be less than 3/32".
I choose twoi A3. I put a view for one different titileblock.
By the way... there is the possibility to aligned the two view exactly in the same position?
"Model line" are not selectable.
Thank's
@AnonymousYou can use Revit's Guide grids for sheet composition. You can set the graphics in VG/Object styles as you like. Personally I like to copy/paste an empty legend with just two intersection reference planes (using reference planes with legends is also how you can snap to those on your title block ie.)
You can reduce the size of your dimensions. Duplicate a dimension style and set it up as you would like it with samller text.
@martijn_pater sequential images
"You can set the graphics in VG/Object styles as you like. " for dimension on aligned object in block?
In which way, sorry?
"Personally I like to copy/paste an empty legend with just two intersection reference planes (using reference planes with legends is also how you can snap to those on your title block ie.)" ==> can explain me with a sequential images, plase?
Thank's
@barthbradley "Duplicate the view (without detailing), set the appropriate view scale and dimension/annotate it from scratch. That's the fastest and easiest way IMO/E. "
==>I can't Duplicate a view
Two allign the two ugual object in two titles with the same size (ex. A3) is using the grid?
