Welcome to Autodeskโ€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Insert row to Revit Sheet List
11 REPLIES 11
Message 1 of 12
reut.h
450 Views, 11 Replies
im trying to add a blank row to a sheet list on Revit 2021 (not parametric, just for information)
for some reason it doesn't work, any ideas why?
Thanks ๐Ÿ™‚
โ€ƒ
Labels (3)
11 REPLIES 11
Message 2 of 12
in reply to: reut.h
Insert Row is for Key Schedules.
Message 3 of 12
reut.h
in reply to: barthbradley
Thank you for your comment. The Schedule on the left is a sheet list, so I know its possible to add the row
Message 4 of 12
in reply to: reut.h
You specifically asked about Insert Row. I answered your question accurately.  That blank row shown in your screenshot is not done via Insert Row, however there are workarounds to do that.
Here one way:
Message 5 of 12
reut.h
ok, and what is the workaround?
Message 6 of 12
in reply to: reut.h
My screenshot above shows how to get there by checking blank line. That not work for you? You want other workarounds?
Message 7 of 12
in reply to: reut.h
Message 8 of 12
TripleM-Dev.net
in reply to: reut.h
Hi @reut.h,
Something like below?
If there's a Viewtemplate attached to the schedule, the editing is blocked (even the parts that can't be controlled by the template)
Remove the viewtemplate from the schedule, edit the header or any other part and then re-attach the template if needed.
- Michel
Message 9 of 12
in reply to: reut.h
Are you trying to create/convert Placeholder Sheets?
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-2A41A029-A537-4D3A-AFF7-D9D4502B5238
Message 10 of 12
reut.h
in reply to: TripleM-Dev.net
Hi, Thanks.
Yes, that's what I need.
Sorry, I wasn't  clear enough ๐Ÿ™‚
Message 11 of 12
reut.h
not sure what are placeholder sheets.
im trying to add rows like @TripleM-Dev.net showed in the screenshot.
Message 12 of 12
TripleM-Dev.net
in reply to: reut.h
Hi @reut.h,
The additional title rows can be added with the Insert button, from the shared screenshot they are grey'd out because the schedule has a template attached, set it to none and those tools become available.
Or the active selected Cell isn't a Title Cell but a Cell of the Data of the Schedule
1. Make sure the title is on in the schedule appearance:
ShowTitle SettingShowTitle Setting
2. Select the title cell and click on "Clear Cell" otherwise changing the title value also changes the name of the schedule itself.
Clear CellClear Cell3. Use Insert rows to add rows above or below the selected title cell
Edit optionsEdit options
 You can also merge cells, edit the shading, height, width, text content, text font/size etc. on the Title Cells.
4. Additionally the Title cells CAN also display certain Project information data or add the Schedule name back with the parameter select comboboxes: (available data depends on Schedule type)
Click inside a Title Cell and change the Category + available parameters from the dropdown comboboxes seen below.
Add Model data to Title CellAdd Model data to Title Cell
Hope this answers the post?
- Michel
Forma Design Contest
Technology Administrators
