Insert information in a Instance parameter which is applied to few categories
1 REPLY 1
282 Views, 1 Reply
Hi there.
This is what I am doing:
I have created a new shared parameter for every instance in almost every category of my model. I will use this parameter to link every model element with my planification on ms project throw Navisworks or Synchro.
This is my problem. I already have another instance parameter in the same model elements in which I have a code. In a excel sheet I have de relation between the code and the plan codes I have to put in the other parameter.
I am trying to do this with acces, exporting the model data base but how can I make to update the data base with the plan parameter affecting to all categories at the same time?
Thanks in advance.
1 REPLY 1
tanayswarupam
@Anonymous  This can be done easily with the help of Dynamo. Have you tried already?
