I have a wall that has the inner wall layers appearing as halftone. I checked VG, Override Graphics, and Object Styles and non of them are set to halftone. New construction filter is OK also. Cut Line Styles is not checked. What else would be controlling these please? Also, the wall appears as it should when I copy it into a new project.
Gelöst! Gehe zur Lösung
Gelöst von anze.kumar. Gehe zur Lösung
Is it really halftone or are just the lines grey (or halftone). Maybe it is the Material properties of inner wall layer (CutLine style and Projection Line style).
Also check if you have any Filters based on materials set.
Thank you! It was Object Styles> Walls > Common Edges being set to gray. I was unaware that's where you set the inner wall layer line weights.
