I have a toposurface that was created previously in the project file I'm working on, but I cannot access it now.
I can access it to makea graded surface from it but cannot do anything else w/ it.
How can it be frozen and not even able to beselected?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Is it pinned? Maybe Pinned Elements are not selectable. Check the setting in the dropdown under "Modify".
B,
Thanks I actually found the issue.
There were separate Design Options that I forgot about!
P
