Hey!
for my architectural model i have seven levels. each level is different from each other. when i put my plan views in sheets i want to be able to move the grids closer to the the walls, when i do this in one plan view, the grids move in all the views. Is it possible to move the grids in a way that it doesn't effect every view?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
This works really well, but the problem is that my grid dimensions does not show in the section box, because the dimensions are set outside the box. do i have to do individual dimensions for every scope box?
