Increase Polyline Amount On Curve for .dxf Export
3 ANTWORTEN 3
Nachricht 1 von 4
336 Aufrufe, 3 Antworten
Hello all,
I am trying to export from Revit into another software and the polylines are rebuilt pretty crude when doing so. Is there a setting I can adjust to increase the polyline count?
I can't seems to find another thread with this same issue with respect to .dxf files.
Thank you!,
Brad
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Anonymous
@Anonymous
Crude and segment curves output in DWG/DXF has been raised several times on this forum as well as other forums and blogs. In Revit there is no such option...depending on the case/geometry, you could be able to refine the Mesh/Polylines in the end Application
I have not experienced that myself, but I have seen it in files from others, usually in specific display mode (the shaded or realistic) and namely small fabrication parts which are actually smaller than what should/could be modeled in Revit.
Nachricht 3 von 4
syman2000
AutoCAD has Polyline edit and you can modify the polyline to be curved smooth or jagged. Unless you are looking for specific workflow.
Nachricht 4 von 4
Revit "Polyline"?  What do you mean by "polylines are rebuilt pretty crude"?
