Increase depth length for stairs
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
cadedu22
395 Aufrufe, 3 Antworten
I hope title is correct.
Is it possible to increase first stair or whole stair platform depth length?
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: cadedu22
@cadedu22
This you mean?
  • Go to west view>>> Select and edit stair >> grab top Handle and stretch it to reach level
  • Edit type of the Run
  • Change structural depth to 600
  • In Plan view place a floor (create a type single layer 1000mm thick - same material as stair)
  • Join Geometry
Nachricht 3 von 4
cadedu22
als Antwort auf: RDAOU
This type of length.
When stairs are casted in situ, they are way longer in ground, or when they are cut from whole stone, it's can go way deeper into ground
Nachricht 4 von 4
RDAOU
@cadedu22
Add a floor and join Geometry... see steps in Message 2 above (GIF updated)
Alternatively, instead of using the stair tool, you can model it in-place as an extrusion  (use category Stair or Generic Model with Host Rebars enabled)
