Incorrect mapping of imported SketchUp model
3 ANTWORTEN 3
Nachricht 1 von 4
ana.lyubenova
577 Aufrufe, 3 Antworten
Hi all,
I imported a Sketchup model in Revit (see attached). Both objects (the armchair and the stool) are assigned the same material; however on the stool the texture is scaled 100 times. Is this a known issue, a bug? Is it related to the imported model itself; is there a way we can avoid it?
Ana
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: ana.lyubenova
Can you share the sketchup models?
Nachricht 3 von 4
ana.lyubenova
als Antwort auf: ToanDN
Sure. Here it is.
Nachricht 4 von 4
For some reason I cannot import the SKP file directly in Revit so I had to export it to DWG.  Upon open the DWG file, I realized the ottoman cushion block was scaled ~1/100 compare to the rest.  To fix it, I think you have to explode that block completely.
