Incorrect dimensions of exported DWG file from Revit 2016
4 ANTWORTEN 4
Nachricht 1 von 5
glallier
746 Aufrufe, 4 Antworten
When trying to export a DWG file from REvit 2016, the dimension values on a broken wall section are showing the incorrect information.
The first image shows the DWG when opened in Autocad after exporting from Revit.
The second image shows what the value should be and what it is in Revit when exporting to DWG.
The DWG value of this dimension changes to the actual measured dimension and not the conceptual dimension taking in account of the break view portion.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: glallier
i have same issue. any solution?
Nachricht 3 von 5
pendean
als Antwort auf: Anonymous
Without your actual files its hard to tell what you have going on.
Nachricht 4 von 5
CAD exported from Revit 2019 shows the same dimension text as in Revit, but if you edit that dimension in CAD (touching any grips, double click the text, etc), then the value will turn to the actual length.  I didn't have time to test win other Revit versions.
Nachricht 5 von 5
zhuliyi0
When will this bug be fixed?
