The footer is displaying a different line pattern over the right side of the floor (there are 2 floors next to each other). I need it to be consistent.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
It does not appear that the footer line is coming through. See the line appearing through when highlighted:
Then you have more than 2 overlapping lines. Keep overriding with the Invisible linework until only one remains. You can also join geometry adjacent elements to clean them up.
