Inconsistent lighting fixture render
steve
Message 1 of 44
steve
Hello all:
I am using the identical recessed can lighting fixture in two different models. In short, the fixture renders correctly ('illuminated' and throws light) in one model, but not the other. The render settings of the two models are identical, and the lights are turned 'on' as part of that setting for both.
A basic draft mode render or a cloud render yields that same confusing and frustrating result. How is this possible?
Any help is appreciated!
Replies (43)
Message 21 of 44
Relax and take your time. I am cooking.
Message 22 of 44
steve
Pardon my ignorant question, but I don't understand this "blocking" thing?
Further, if the family works in one model, but not the other, I don't understand what that has to do with the family?
Message 23 of 44
@steve: it has to do with Materials. Something translucent in one project, is not translucent in another.
...transfer Project Standards: Material Definitions from "good" project to "bad" project and see results.
Message 24 of 44
steve
Sorry, I don't follow "delete everything but the Ceiling Opening and the Light Source"?
Message 25 of 44
@steve: the light source is surrounding by geometry. That geometry's material transparency is different in one project from the other. Get it? Just do as I said and delete everything but the Ceiling Opening and the Light Source from the family and reload it and re-render it. Does it render well or no?
Message 26 of 44
steve
Transfer 'Materials' or 'Materials Definitions' (I don't see the later, only the former)?
Message 27 of 44
steve
Yes, I think so.
Message 28 of 44
Transfer Project Standards
Message 29 of 44
@Anonymous wrote:
Yes, I think so.
Okay...does that correct it for you?
...deleting everything in the family was just a trouble-shooting step. It appears the materials are the blame. Leave the family intact, and use Transfer Project Standards to transfer the material definitions from the "Good" project to the "Bad" project  -- overwriting when prompted. Should solve the problem. No?
Message 30 of 44
steve
Nope.
Message 31 of 44
@steve, buddy, pal...what do you mean by "nope". Nope what?
Message 32 of 44
steve
It did not solve the problem.
Message 33 of 44
What's "IT"?
Message 34 of 44
steve
Transferring the materials did not solve the problem.
Message 35 of 44
Your light is inside the fixture geometry.
Move the light outside of the fixture geometry. You will need to "unlock" the light in Elevation view.
Doing the light section I proposed earlier woul'dve highlighted this common problem.
Since most lights are terribly modeled, I would encourage you not to play with lighting until you are comfortable making your own light families. Lights are some of the most misunderstood families in Revit and 98% of light fixture models are garbage (wrong lumen value, wrong light type, wrong light location, wrong materials, wrong Light Loss Factor, etc).
You best bet otherwise, is to find some of the few lighting manufacturers that provide accurate Revit light families, but they are few and far in between.
PS, if you want more light, adjust the "initial intensity".
Message 36 of 44
steve
Okay, so I discovered a "work around" late last night (purely by luck) that solved the problem I've been having.
@Anonymous is correct (sort of ... I think ... yes?) about moving the light source. I tried his suggestion, and it did cause light to emit from (and appear to illuminate) the light fixture, but the result was kind of harsh looking. Disclaimer: I'm assuming I did it correctly.
The project I'm using this in is a residence, with a GWB ceiling placed snug up against a framed floor system. So the fixture is occupying the same 3D location as the floor. If this was what folks were saying was "blocking", I now get that. I was of the impression blocking literally meant something in front of the fixture. In this case, the fixture (light source anyway) was located IN the floor, unable to shine through. My test model only had the same simple GWB ceiling, but no floor system directly above it ... hence no 'swallowed' light fixture!
My workaround was this ... I simply (temporarily) eliminated the floor framing (where the light source was situated) in the floor family, thus creating a "void", and the lights 'rendered' pretty much as expected.
Message 37 of 44
Glad you got it working. Indeed, lights being in things is one ofthe most common source of darkness.
You can change the light type to a spotlight to get better results or better yet, use a photometric web. Any light that does not use a photometric web is basically BS, but it will do the trick in most cases despite the photometric innacuracy.
For the future, reveal your light sources in sections to troubleshoot, it will save you a lot of time Smiley Very Happy
Message 38 of 44
steve
Thanks for the tips, very helpful! Is the photometric web, the choice highlighted below?
Message 39 of 44
Yes, it wil bring up a new option in your properties for a photometric web.
Then you can point to an ISE file of the light you want to reproduce. For example you can pick a light from Kurt-Versen, find the right photometric web and add it. The rotation angle for IES files is usually -90 degrees (weird, I know).
http://www.kurtversen.com
It's a bit of a complicated pain if your IES came from an LED fixture. For now, jsut avoid LED IES files or else your ligths will come out as reverse rainbow colors.... Good old Revit.
If all this is to complicated, jsut pick the beam on the left of the phometric button. This is more begginer friendly, despite impossible lighting.
Message 40 of 44
I have no idea what is being espoused here in my absence, but here are 2 rendering images from the RVT file (Test Lighting.rvt ‏9676 KB) that @steve uploaded to this site yesterday. Nothing whatsoever was done to the Family or the Project. One is a Raytrace (approximately 1 minute), and the other is a Render in Draft mode for Screen resolution.
