- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've run into a strange/annoying problem.
In a hotel, where the layout is grouped and copied to the different levels, I've noticed on 1 level the group is misplaced by 5cm. Logically all walls are shifted 5cm along the Y-axis, the actual room size/layout doesn't change.
However in 1 room, the entry door isn't moved at all, it is in the same space as the doors on the other levels. The distance between the centre of the wall and the centre of the door should be 71cm.
Has anyone come across similar problems?
Before you suggest ungrouping: I've tried this, but then I lose a bunch of filled in parameters, like Mark etc. So I can't do this.
