Including room finishes in a schedule from a Revit Link
6 ANTWORTEN 6
Nachricht 1 von 7
stephen.melhuish
1101 Aufrufe, 6 Antworten
Hi. I'm hoping someone can help; I've spent 2 days trying to resolve this problem.
I have a model including a link. I have created a Schedule Key under the Category 'Rooms' and then a Finishes Schedule with the Key as a Parameter. So far, so good. BUT, of course the Schedule won't allow me to add finishes for the rooms in the Link.
Cells in the schedule relating to rooms in the host allow me to access a drop-down, but cells associated with the linked rooms won't
I've ticked Include Elements in Link, I've tried creating and using Shared Parameters across both models. And I'm now at a loss.
If anyone can help, I'd be so grateful. My last-chance option would be to create a Generic Schedule and just fill in the cells manually.
6 ANTWORTEN 6
Nachricht 2 von 7
syman2000
als Antwort auf: stephen.melhuish
You cannot change any link parameter in the central model. You have to transfer schedule key & finish schedule to the link model. Then you have to set those key & finish schedule parameter in the link model. Once you've done that, your central model will show those parameters.
Nachricht 3 von 7
stephen.melhuish
als Antwort auf: syman2000
Thank you for your prompt reply. Do you mean transfer schedule key etc by using Transfer Project command ?
Nachricht 4 von 7
syman2000
You can do that or you can place the schedule on a sheet and copy the schedule from sheet to the link file.
Nachricht 5 von 7
Thank you for your help; just so I am clear, do you mean;
1. create the Key Schedule and Schedule in the link and then copy it to the host, or
2. create the Key Schedule and Schedule in the host and then copy it to the link ?
Nachricht 6 von 7
syman2000
Once you create your key schedule in your central model, you can copy those schedule and paste it on the link model. All those values you created will be in the link model. What I find useful is placed those schedule(s) on a blank sheet. Then select those schedule(s) copy it and go to the link and paste it on the link blank sheet. That way you don't need to transfer all the schedule from the central to link and only copy the certain one on sheet.
Nachricht 7 von 7
stephen.melhuish
Brilliant. It worked !! thank you.
I did this by simply using a Finishes Schedule. I might next try using a Finishes Key Schedule into a Finishes Schedule and seeing if that works as well.
