inclined SE col problem
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
261 Aufrufe, 2 Antworten
hi dears
i have an inclined wall cladding assigned on mass supported by inclined steel col
its build in family as inclined (not using slanted col because heights are different for each col)
1- wall not hiding the col correctly
2- col not cut in plan correct (col from ground to roof when i cut it in roof it shows me its cut profile in ground floor)
is there is any way to correct that easily??
many thanks in advance,
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Edit the column family and untick Precut... box from properties.
Nachricht 3 von 3
als Antwort auf: ToanDN
Many thanks my dear for your support
it works fine now
