Revit tells me this is a "5" slope which I take to mean 1 in 5
But when I analyse this slope in Rhino it is close to a 1 in 3 (as intended):
Can anyone help explain what's going on here?
Btw I and my practice would prefer to be able to annotate slopes in a "1 in X" or "1:X" format but I understand this is not possible in Revit?
TY
Gelöst! Gehe zur Lösung
Gelöst von hughecchapman. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Many thanks @barthbradley @ToanDN.
In terms of the inaccuracy, I've discovered that changing the spot slope type from Slope 1_200 to Slope accu in the properties panel gives an accurate slope value.
I'm not sure why you would want to round a slope value to the nearest 5 as seems to be the case with Slope 1_200...
Try TAB-Selecting on the SAME spot when place the Spot Slope and see if you get different Spot values
