I first began using Revit with the 2017 version shortly after its release in 2016. It was quite challenging at the time, especially due to the steep learning curve, which made adapting to the software a demanding experience compared to AutoCAD, which I had used previously for my projects.
When did you start using Revit, and how did it compare to other software you've used?
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
I did briefly with Revit 2011. I was in CAD team but pulled over to Revit team because they were struggle with a deadline. I did not model anything but did the code egress plans and schedules. It was much easier than doing it in CAD using attributed tags and attributed extraction table linked to polylines.
I officially moved to use Revit 2013 and it wasn't much more difficult than AutoCAD or AutoCAD Architecture because I never tried to make Revit work the way other programs work.
I downloaded Release 1.0 from their web site after hearing about it at a AIA/CSI meeting. It took a couple years for me to convince our firm to use it so I started out doing residential side projects with it until then. I completely lost interest in AutoCAD/ADT and Microstation at that point. Never looked back.
Steve Stafford
I think it doesn't matter.
The advantage of Revit keeps for verisons (against other softwares).
...And the bugs too.
I downloaded the 2013 for the first time, but I used it very little, but since 2016, I have worked with it almost every day.
