Several things in a working drawing should appear in the plan in a way which does not reflect the normal "cut-look downwards" view.
For example, I would like to show the following as if the cutline passes through them, but their actual position is out of the regular view range - above or (below but within the wall mass):
-Windows
-Ducting cuts in walls, in floors under or above walls, in the floor above
Can this be achieved without manual drawing works?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Try using a Plan Region. You an set the View Range independently from the rest of the view.
Plan Region is a good suggestion by @cbcarch.
Another method is employing the ol' invisible model line trick. You'll see it referenced in AKN Articles. Here's how it's done:
Revit OpEd: "Aaaah,The old invisible line trick, eh "99"?"
FWIW: Window and door families are not cut based on the cut plane defined in project views.
Instead they are cut based on the cut plane defined in the family's plan view.
Revit | Windows and Doors not showing as expected | Revit Products 2019 | Autodesk Knowledge Network
