In-Places Families cannot be found
4 ANTWORTEN 4
Nachricht 1 von 5
nghiace
575 Aufrufe, 4 Antworten
Dear All,
There are quite a lot in-places families in the model and it contains 1 instance. When i tried to edit the in-place family there was nothing inside but if i model a solid extrusion in that environment it appears. Does anyone in the forum has the same issue? any help would be appreciate. Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: nghiace
They can't be empty. There has got to be something in them.  They are probably voids that cut something in the project.
Do this: In 3D View (Zoomed to Fit and Wireframe mode), select one of the In-Place Families in the Project Browser, right-click on it and select "Select all Instances"=>"Visible in View", and then press eyeglasses button on the View Control Bar and choose  "Isolate Element".   Betcha you see a "ghost".  That's your In-Place Family.  How'd I guess? Did I do good?
Nachricht 3 von 5
nghiace
als Antwort auf: barthbradley
Thank you so much for your reply but...nothing there. Actually I have a test on an empty project and yes the in-place family cannot be empty. But these in-place families like a ghost in my model :enttäuschtes_Gesicht: it contains nothing.
Nachricht 4 von 5
nghiace
Dear All,
The revit model (version 2018) contains those in-place families has been added for your reference.
Nachricht 5 von 5
I looked at your file and I'm see exactly what you are seeing --- NOTHING! Arrgh!  I'll have to come back to this one after another cup of coffee.
To be continued...
