In-place walls showing transparent in all 3d views
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
L.S.
403 Aufrufe, 2 Antworten
On Revit Lt 2020 my in-place walls are see-through in all 3d views. I don't want them to be. All other elements are not transparent, just the in-place walls. I imagine there must be a setting that did that. How can I fix it? Thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: L.S.
Could be any number of reasons. Maybe you are in Wireframe Mode. Maybe you assigned the wrong Material. Maybe you modeled it as a Mass and it's using the Default Mass Material.
Can you post some illustrations or the file itself?
Nachricht 3 von 3
L.S.
als Antwort auf: barthbradley
Thank you. The problem was the material. I had not assigned one, so it was whatever was already there.
