I modeled some deck joists using in-place wall (Revit Lt, so all "model in place" are walls). When cutting a section through, it doesn't show the joists hatched, while I'd like to show them filled with a solid gray hatch. How can I do that?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
check below video. you need to assign a material to your wall after associating it to a material parameter. You can either add new parameter or use an existing one inside the family.
Mostafa Elashmawy
Or... you can just edit the in-place model and assign the material there. No need for the parameter, although it is easier to adjust later if you do add one as shown above. I usually create an instance parameter there.
