Okay so I've been trying to trace a sketchup file through massing and it's taken me a while to do.
Then I find out I can't form roofs, only walls. And it looked like this when I zoomed into the wall. What's going on here and how can I fix it?
Attached is the file with the issue.
Thanks!
This is what's going on when I pick wall by face.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sometimes Roof by Face doesn't work and only Wall by Face will work. That's good thing, not a bad thing. Sometimes neither work. That's a bad thing.
Yes but the issue is that I need the wall to be a roof so that I can place interior walls that attach to the roof.
There are other ways to "attach". Attach to a Ref. Plane. Edit Profile of Wall. Etc.
Yes but not with this form since the wall/roof is curved at at an angle.
I cant make a reference plane because the surface is curved, and I can't edit profile for it to work because the roof is at a weird curve.
Get imaginative. Join the Walls to create an edge. Trace this edge when editing profile of a wall.
I suppose that works. How do I trace the edge to keep it visible while I'm editing the profile?
The join lines disappear as soon as I enter the editing mode.
