In-Place Mass shape is not converting into roof
8 ANTWORTEN 8
Nachricht 1 von 9
sfashah
6913 Aufrufe, 8 Antworten
I have some issue. My custom In-Place mass shape is not converting into roof anybody help me to solve the problem.Frustrierte Smiley
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: sfashah
Can you share the mass?
Nachricht 3 von 9
sfashah
als Antwort auf: ToanDN
yeah sure
Nachricht 4 von 9
This works with using a wall by face and setting it so the surface of your mass is the external surface of the wall
The ridge will not work otherwise
Nachricht 5 von 9
semko_dm
Hi!
Probably, too complex for Roof by Face. You can use Wall by Face instead.
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Nachricht 6 von 9
sfashah
als Antwort auf: Anonymous
thank you so much guys for your opinion but my question is different ...
i know about the wall option but i have seen this video ( https://www.youtube.com/watch?v=qXaq6ElI9S0this video guide me for making the element from roof .
can you please guide me how to make this because i have done all the things which is shown in tutorials but i can't make this element from roof that's my problem Smiley (traurig)
Nachricht 7 von 9
Your form is too extreme so Revit cannot create a Roof from it.  I "rationalized" it a little bit to smooth out the sharp turns and it works.
Nachricht 8 von 9
semko_dm
Did you watch that tutorial carefully?
That guy also failed to make roof similar form.
You can start with simple form, and create a Roof by Face. Than edit your Mass a little bit, and update the roof. Repeate this two steps some ammount of times and you'll find the boundarys of roof flexibility, may be a bit less curved roof will work properly.
Dmitriy Semko
BIM-Manager
Blog
Nachricht 9 von 9
Hello
look you have to know that revit will not always respond to what you give him as command in this case of a complicated roof you have to make it with sub steps before getting to the final shape and after each step you will make an update for the face so you will have the desired form
i attached a file where i made an organic roof but first with a simple profile then i added profile ( in your model you added edge try to add profile so you wont cut the mass into two parts ) and modified them and after each modification i made an update for the face .
Regards ,
Arch Aly Rashid
ACI , BIM coordinator
If you find my answer is helpful feel free to give me kudos and if it is the right solution do not hesitate to mark it as a solution . Thank you
