In Place Mass: Roof
3 ANTWORTEN 3
Nachricht 1 von 4
885 Aufrufe, 3 Antworten
In Place Mass: Roof
I'm having trouble modelling a roof. On top of the building is a large organic shape which is a glass system but it needs to be slightly rounded for drainage reasons, which I can't seem to figure out how to create. When I create an in-place-mass, it doesn't allow me to then create a roof from that face. I think it's because the shape is too strange. I'm able to create it flat but as soon as I add any height to the shape, it refuses to work. Is someone able to help me? I'm just after an ever-so-slight curve ! Pictures attached.
Thanks in advance,
Fin :leicht_lächelndes_Gesicht:
3 ANTWORTEN 3
Nachricht 2 von 4
bin
als Antwort auf: Anonymous
You can try Generic Model.
Nachricht 3 von 4
Is the "Glass" the roof you are talking about?  Created by applying a Curtain Wall System to a Mass Face?  If so, I can see how that wouldn't work too well.  I'd suggest dividing the Mass surface and applying a Pattern-Based Curtain Panel Family instead. It'll look prettier too.
Nachricht 4 von 4
als Antwort auf: barthbradley
Great thank you! :leicht_lächelndes_Gesicht:
