In-Place Mass Crashing Render
10 ANTWORTEN 10
Nachricht 1 von 11
668 Aufrufe, 10 Antworten
Why does my render crash when using In-Place Mass? (the two transparent, grey objects in the background are the in-place masses)
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
Interesting hypothesis. How did you determine it was the In-Place's fault?  I've Rendered many many Views having In-Place components without issue.   What are the In Place's Material Appearance properties (i.e. Asset, Image, etc.)?  And, what version of Revit are you using?
..Sorry. I mis-read. I've never Rendered a Mass. Still, I would be curious to know if they would accept a Rendering Material.
Nachricht 3 von 11
aRcHiTeCt.JM
... maybe your PC needs more RAM (memory)
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 4 von 11
aRcHiTeCt.JM
... try this:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
... maybe changing the material of the mass you will be able to render
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 11
als Antwort auf: aRcHiTeCt.JM
Yep. I can Render Masses without crashing.  Which brings me back to my original question: how did the OP figure is was the Masses that were causing the Crashing.  Was there an Error thrown up?
Nachricht 6 von 11
als Antwort auf: barthbradley
I rendered without the In-Place Mass turned on and it worked fine. I believe the issue is I either improperly imported the masses or messed up their material appearance properties.
I am using Revit 2018.
I tried using an earlier version of my project and it seemed to have fixed the problem.
Thanks.
Nachricht 7 von 11
I fixed the problem by using an earlier version of my project. The issue was that I either improperly imported the masses or messed up their material properties.
Nachricht 8 von 11
Imported? Is it an In-Place Mass built from imported geometry?
Nachricht 9 von 11
... try this:
Thanks. I will try this. I believe the issue was material related or the way I imported the masses. I'm currently using an earlier version of my project and it seemed to have fixed the problem.
Nachricht 10 von 11
Yes, "Import CAD" (ACIS file).
Nachricht 11 von 11
Might have been rectified by an Audit of the other file.  FWIW.
