I'm modeling a project specific stair as an in-place family. It consists of 4 different extrusions that align to 4 different walls. Every extrusion has to be precise to guarantee the right slope ratio.
The problem is that I want to lock the extrusion paths while still being able to move the extrusion. I found no way to do that so at least I could lock the extrusion to prevent editing. But here's the next problem: When I'm finished editing the in-place family i'm able to edit every single extrusion from the main model (although they're locked inside the in-place family). Is there no way to lock the single elements?
Best regards
Ben
Why not set up parameters to control?
For instance, associate the "Extrusion Start" and "Extrusion End" to Parameters.
A couple of ways you can do this.
1. Use reference planes to lock the extents of the stairs that cannot be locked to walls.
2. Use the Pin tool in the modify tab to prevent any edits of the in-place component.
