Can you please compose your question in a better way? It's not clear.
You can assign a different text size to your dimension type just like you can in AutoCAD. Alternatively, you make a new type if the large size is desired and used elsewhere. A common text size for dimensions is 3/32".
Edit: I think you want fraction numbers to be smaller than regular numbers. That is not possible in Revit.
Disregard this if the above is what you meant: Write some letters on paper at 1/2" and 3/4" height and you will see they are obviously very large for typical architectural drawings. Use a smaller text size for your dimension (i.e. 3/32", 7/64", or 1/8").
do you mean :
or not?
