In a section a window is showing a strange gap between wall and window which shouldn't be there?
2 ANTWORTEN 2
Nachricht 1 von 3
emmanuel_boakyePJCYR
202 Aufrufe, 2 Antworten
Hi, I have a window family which I have inserted into a wall, in a section, the window shows a gap top of it which shouldn't be there. In the family editor the window seems fine but after loading it into a project and placing it in a wall, it shows a strange gap the top of it, I have attached an image below, the highlighted yellow area is the gap that I am describing, it shouldn't be there. Does anyone know how I can get rid of the gap and get the window to fit within the full size of the opening.
2 ANTWORTEN 2
Nachricht 2 von 3
Check the constrains, or for more specific solution...send the rfa file
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
Could be just the Detail in the Family - not the actual Model Geometry. Is it the same in 3D? Use a Section Box to find out.
