Does anyone know how to, in a family, attach a clearance zone to the level and allow it to stretch with project Elevation from Level or Offset from Host.
Is the Clearance Box Aligned and Locked to Reference Planes/Ref. Level in the Family? Doesn't look like it from your screenshot. If you want the Clearance Box to be parametrically-sized, then you need build that intelligence into the Family just like you would anything else that is parametrically-sized.
...is this what you have in mind? See attached.
See my first post again. I added something for you. See if that RFA works for you.
No, the bottom of the clearance zone has to be stretched to the level after placement. I want it there already and stay there when the elevation is changed. This is for the detailer so they do not have to stretch or align anything after placement in plan view. They just have to change elevation in properties and that is it.
Your family functions like that now.
Lock the Clearance Box to the Level.
You're locking it in the project. I don't want to have to do that. I guess my intent is not achievable.
Look at the revised one (CB-2). If that ain't what you want, then I have no idea what you are looking for.
@sdonahay wrote:
Unfortunately, that is still not it. You still have to go to an elevation view and drag the bottom of the clearance zone to the level below. The whole intent of my request for help is not to have to do that. Once you place the VFD in the plan view and set the elevation in properties the VFD moves up or down but the bottom of the clearance zone stays at the level it is placed on. It may just not be achievable.
It can be done. It's a two-step process though. You need to "anchor" the bottom of the Clearance Box in the Project.
