Improved Topography Hosting
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jem.cicekdagKV2ZC
323 Aufrufe, 2 Antworten
I primarily run into the parking spaces needing to be hosted to the topography as the carpark surface is never going to be flat and is always sloped for drainage. The parking space never follows topography well (or at all) even when the family has been modified with the "always vertical" option ticked off.
This also goes for other families which i have experienced this, the family gets chucked into the topo and lost in 3D view & on plan - i often have to reside to drawing 2d lines over the element so it at least presents in drawings.
Improved functionality of this will also improve renders, as a floating object - although sounds cool, at this time is quite unrealistic lol
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jem.cicekdagKV2ZC
 I think you want to post this to the Idea Forum.  Or did you have a question for us?
Nachricht 3 von 3
jem.cicekdagKV2ZC
als Antwort auf: barthbradley
Ooop, my bad! Will post it there :leicht_lächelndes_Gesicht:
