improper use of boolean expressions
4 ANTWORTEN 4
Nachricht 1 von 5
shahin_kiyomarsi
440 Aufrufe, 4 Antworten
Can someone explain whats wrong with this formula?
4 ANTWORTEN 4
Nachricht 2 von 5
mhiserZFHXS
als Antwort auf: shahin_kiyomarsi
I'm guessing its because it looks like you typed in SF, though it'd be easier to tell if you showed us the error you were getting.
Nachricht 3 von 5
shahin_kiyomarsi
als Antwort auf: mhiserZFHXS
the error is improper use of boolean expressions
Nachricht 4 von 5
ralphdenhaan
I think the error is because the Occupancy is a Text parameter instead of a number/integer. You can add a custom parameter for the Occupancy and then use the formula:
roundup((Area / 1 m²) / Occupancy_integer)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 5 von 5
What is the parameter type of Occupancy?
