Hello!
I get the Improper use of boolean expressions message, i dont know how to make it work.
IF (Number = 26, Area / 2, Area)
where Number is the room number. I want specific rooms to be divided by 2 for their final area.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
What type of parameter 'Number' is?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Its the room number (in the room tag), does that make it a text or integer?
That type of parameter doesn't work in calculated value.
you have to create a Number-type parameter and it works
The formula works! however, i dont get that other window with the categories where you choose "Habitaciones". I get an empty column on my schedule
Nevermind its working now! I had to edit the idd in the room tag that i wanted. Thank you so much!!
You have to edit the parameter in every room ![]()
great!
Please accept it as a solution if it has solved your doubt!
Quick question, how do i write the statement if there are more numbers i want to choose? for example, I want that the formula divides the area by 2 for specific items on the list with idd 26, 28, 30 and 32.
If you do it that way your formula will get very long and prone to errors.
Just add a yes/no parameter to the schedule, name it Half Area, tick it for any rows need to be divided by 2, untick for the rest, then use the formula:
if (Half Area, Area/2, Area)
Do it with a yes/no parameter
