impossible extract .ifc
Message 1 of 8
Very angry with problems generating .ifc file from a model of just 144 Mb, it seems impossible.
Til now generic answers from support.
Replies (7)
Message 2 of 8
dzanta
what version of revit are you using?
is it up to date?
can you give us the file so we can export to IFC for you?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Hi dzanta,
I use Revit LT2016, up to date.
I can send you the file, but my group still need to work on the model, so
is important for us to understand why it has this problem (other models are
ok extracting ifc).
We tried extracting on 2018 version, on a collegue's cp, but the same error
happened.
If you export the .ifc file for me it's good, but we will need to ask you
this once more when the work on the model will be finished.
Tell me please how to send th file, thanks! Ugo
Message 4 of 8
dzanta
Since your other files are functioning properly, the file in question could just be corrupt.  Have you tried the Audit and Purge commands prior to IFC export?
You can upload the file to my Dropbox link....
https://www.dropbox.com/sh/ueilx1q5wnic5zm/AABEuUFh-fhXO7zYqYJqBKAda?dl=0
Message 5 of 8
Hi, even after audit and purge, no way to avoid that error.
Now I will upload tha file in your dropbox
Thanks! Ugo
Message 6 of 8
Hi
the link to your drop box opens a page where I can't find a way to upload the file.
I still can' extract .ifc from that model.  Program works right on every other project we have done.
I had this morning a meeting with the City and I had to admit that the ifc file is at the moment not available.  😞
Hope to receive useful helps.
Ugo
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
The solution is here.
Rafal Gaweda
Message 8 of 8
Hi Rafal, thanks, it works. I still wonder why I don't need this setting
with other files, but it'enough! Thanks again. Ugo
