Importing SAT file into Revit 2021 with Dynamo?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ericafardo
1275 Aufrufe, 2 Antworten
I have been struggling with Dynamo (within Revit 2021). My current goal is to import an SAT file (from Fusion 360) into Revit 2021. I have recently discovered Dynamo located under the manage tab.
This is the tutorial I have been following mainly: https://www.youtube.com/watch?v=jf-c4mAYt1E
I can not find the correct node that creates lines on the surfaces of my SAT file. I have correctly set up the following nodes: File Path > Geometry.ImportFromSAT + Number > Geometry.Scale.
In the tutorial at 4:43 minute mark, there is a node called "Structure.WireGrid" This node has three inputs: surface, U, and V. And two outputs: Lines, and Points.
This is the node I can not find a replacement for. I have tried UV.ByCoordinates, and DividedSurface.ByFaceUVDivisionsAndRotation.
I have not been able to get past 4:43 minutes into the tutorial. Have you run into this problem before?
Edit: I have tried opening Revit into Metric Mass family template mode
2 ANTWORTEN 2
Nachricht 2 von 3
_Vijay
als Antwort auf: ericafardo
@ericafardo  hi, there is a sperate forum for the dynamo. I hope you posted there.
Nachricht 3 von 3
ericafardo
als Antwort auf: _Vijay
im looking for it now
