I have a 500mb obj file that revit won't index. Has anybody seen this or had this problem?
Thanks! ReMake helped to get the OBJ file down in size significantly but Revit still wont index it (creates a 1kb file that causes an error). Any additional thoughts?
I think you should do some troubleshooting.
-Try with another (simple) obj file and see if it works
-Try to cut up you mesh in several parts and see if it will import then.
-Repeat this with the other parts and see if there is a particular part that causes the problem
There is a paid app in the app store, Mesh Import from OBJ files (for Revit 2015 & 2016) that might be of use (not used myself)
Louis
Please mention Revit version, especially when uploading Revit files.
