I have created a model in houdini.
And i need to import model to revit. How to do this?
I have model as OBJ file.
I can also export out as:
* Alembic...
* Filmbox FBX...
* GLTF...
When i tried to do that i get an error that i do not understand how to fix / proceed
I was able to find path via 3d max to get model in to revit but it seems to be as unified mesh. How to fix it. So i can actually modify mesh in revit?
A bit old thread, but the answer is still relevant. You can import (glTF, OBJ, Collada) using the Import 3D extension, that largely expands the Revit capabilities to import 3D geometry. What I like is the possibility to structure the elements and split in accordance with materials and also transfer the color information from the original model.
