hi
that doesnt work , ive tried all options there , none of them seems to work too . when i import the dwg file the extents/limits are way too large (when i select the imported dwg , it shows me the border and its way too big and that is the problem) .
@Anonymous.melhem wrote:
Hello
I have a dwg file, when i try to import it or link it i get the " more than 20 miles ..." warning , even though the drawing is drawn and scaled properly (30m by 40m building on 1:100 scale , so it should be fine),am i missing something ?? is there a way to prepare the dwg to be imported to revit ?!
I am a bit triggered when you said "the drawing is drawn and scaled properly". Is it drawn at full scale, e.g. 30 meters measured as 30 meters? Scales of the viewport, plotting, annotation, etc.. do not matter.
Also, when you thaw, turn on all layers in the CAD file and do a Zoom Extent, do you still see the building at a reasonable size and not a tiny dot on the screen?
If possible, move the lines in the CAD file close to the zero zero origin.
