Importing DWG into Revit - Changing between Colour and Black & White on veiws
7 ANTWORTEN 7
Nachricht 1 von 8
CEDSTUDIO-1
1474 Aufrufe, 7 Antworten
Hi there,
I have just imported our surveyors DWG file into a new project but every time I make a new floor plan they file changes from Colour to Black and White. Where do you change how this is seen?
Thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: CEDSTUDIO-1
@CEDSTUDIO-1 hello, when you import the cad file did you select "preserve"? thanks
Nachricht 3 von 8
CEDSTUDIO-1
als Antwort auf: ennujozlagam
Thank you for the advice.
I have selected preserve. It changes between black and white or colour depending on which view I am in. For example when looking at ground floor its black and white and then first floor it is colour.
Nachricht 4 von 8
ennujozlagam
@CEDSTUDIO-1 hello, that is strange, can you please post some screen shot of ground floor and 1st floor to see. thanks
Nachricht 5 von 8
CEDSTUDIO-1
Yeah it is! I am though maybe the view was in black and white but I am able to draw coloured annotations.
Please see images below
2016-11-15 11_58_54-Autodesk Revit 2017 - [Sheet_ FP-02 - COMPLEX PROPOSED GROUND FLOOR PLAN - CED _.png
2016-11-15 11_58_25-Autodesk Revit 2017 - [Sheet_ FP-01 - COMPLEX DEMOLITION GROUND FLOOR PLAN - CED.png
Thanks again for any help
Nachricht 6 von 8
Do you have any View Template assigned to the Views where the CAD turns black and white?
Nachricht 7 von 8
CEDSTUDIO-1
als Antwort auf: ToanDN
I have figured out that my issue is conncented to the View Range. When the bottom primary range is set to the the same associated level as my CAD file it is Grey Scale. But when it is offset below only it is colour.
Nachricht 8 von 8
I AM IMPORTING CAD FILE TO REVIT AND WHEN I AM RENDERING IN REVIT THE ABOVE RESULT COMING.
WHILE IMPORTING I ALREADY SET - COLOR TO PRESERVE
PLEASE HELP ME WITH THIS
@ennujozlagam
Tags (1)
