Hi.
I am trying to use 3dsMAX blocks in my revit projects because they are more easy to find and the geometry model is better in my opinion, considering that 3dsMAX is a free modeling tool.
To do it, I`m exporting to autoCAD then import to Revit but when I do it is always missing one part of the model... I can`t import 100%.
I know that the 3dsmax models as very heavy in terms of numbers of polygon, so I`m using a modifier called MultiRes that reduces this number a lot, so the model is very light....but still cant import 100% of the model.
I have also tried to attach the parts....but still the same problem...
* if it´s a 3DSmax issue im sorry in advance....
Thanks!
