I know it's possible and I don't understand why it isn't something I can pick and chose. I know its possible because I've had to delete every "sheet" in order to force the AutoCAD to not upload from paper space. But now I want it to upload paper space and its uploading model space instead. I just can't win. What do I need to do to my AutoCAD file so that it reads the sheet instead of the model?
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
Sheets import paper space. Views import model space. Know your target and set-up the .dwg accordingly. If you want to force paper or model, delete everything in the one you don't want but you will still have to click okay when Revit asks.
BTW, I would be linking those CAD files instead of importing.
