Imported SketchUp model with yellow faces
3 ANTWORTEN 3
Nachricht 1 von 4
582 Aufrufe, 3 Antworten
Hello!
I seem to have a problem with a SketchUp model that I imported into Revit. Some faces in the model show up yellow while others are white as usual. I tried importing/linking the model in multiple ways but it still shows up the same. I also exploded the model in SketchUp and made sure that all the faces are front facing.
I would really appreciate any help!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
The faces are reversed in SketchUp. Open the model in SketchUp and right click on these face and flip them back.
Nachricht 3 von 4
FGPerraudin
hi @Anonymous,
@ToanDN is right,
I will add that in order to identify the reversed faces, you will need to change the display of your sketchup model using that icon:
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 4
als Antwort auf: ToanDN
Thank you for your reply. As I mentioned in the original post, I did check if the faces in the SketchUp were front facing and reversed the ones that weren't. But the problem is still there.
Here's a picture of how the model looks on SketchUp with the "Display shaded using all same" turned on. @FGPerraudin
